Is there a way to remove unwanted portions of an object?
deianwijangcodeianwijangco Member Posts: 3
Hi! I was wondering if there was a way to remove the selected areas? I'm trying to trim the object but the remove extrude function isn't working. (see pics)
thanks!
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    edited January 2021
    There are a multiple ways to do this: Extrude, loft, move face, sweep.
    Here is one method:
    • Create a sketch on a perpendicular plane to the original sketch.
    • Extrude remove that sketch from the original part.
    RENDERCAD
    Sometimes custom features can be faster depending on your application.
    Here is a feature I made for models like this, Intersect Views. You can add it to your tool bar.
    https://forum.onshape.com/discussion/15113/intersect-views-new-custom-feature#latest
    RENDERCAD
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,056 PRO
    The way @deianwijangco has it sketched, you could use a loft-remove between the sketch face and the selected face
  • deianwijangcodeianwijangco Member Posts: 3
    Wow! thanks everyone huge help!
