Sketch : How to link dimension from other dimension ?
ROBOTIS_Japan
ROBOTIS_Japan Member Posts: 4 PRO
edited March 2021 in Community Support
Hi,
My 1st technical question.
Please see below image.
How to link with other dimensions when inputting new dimension?
Is there a Variable list somewhere, should I refer to it?
Thanks first,
  • konstantin_shiriazdanov
    From recent times you can create variable from the input fields of features and sketch dimensions. Type "#" symbol and in the bottom of the list you will see an option to create new variable and insert it in the current input field with desired value thus you can  assign diam 9 of the circle on top to variable, and later use this variable in the dimension of the bottom circle
  • Prachi
    Prachi Member, OS Professional Posts: 262 ✭✭✭
    You can also use the equal constraint to make objects the same size within a sketch. You can use the equal constraint from sketch to sketch so long as the working plane is the same or parallel.
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
  • Eric_Percy
    Eric_Percy Member Posts: 1 PRO
    Shiba,
    I really hope that you get an answer for this as it is one of the things that I miss the most from Inventor. The ability to have a dimension drive another dimension/2 (for example) is something that I used in every drawing.
  • tim_hess427
    tim_hess427 Member Posts: 648 ✭✭✭✭
    @Eric_Percy - As mentioned previously, there isn't a native way to reference other dimensions, but you can easily create variables that can be referenced by your dimensions. (I think there is an improvement request for something like this, maybe called "addressable dimensions" that you can vote on).
    Right now, you can get the same affect by using variables. So, you could create a variable called #d1 which is equal to 10mm. Then, you can use #d1 inside formulas for dimensions, such as #d1*2. The variables can be updated at any time and anything referencing those variables will update as well.
  • Prachi
  • ROBOTIS_Japan
    Thank you for very quickly reply.
    I checked using "#" symbol in sketch dimension, this is nice shortcut!
    It is be close what I want to do.
    Thank you for reply.
    Sorry, the example I presented was not good.
    What I want to do is like below GIF.
    Like Autodesk Inventor, I want to calculate and use other linked dimensions. If dimensions of link source change, dimension of link destination will be changed automatically.
  • Eric_Percy
    Shiba,
  • tim_hess427
  • t_kempKPD
    t_kempKPD Member Posts: 3 ✭
    Ya this is about to make me get a refund
  • tom_auger
    tom_auger Member Posts: 134 ✭✭
    I'm just trolling these older posts that talk about driving dimensions to provide updates to others who are coming to the topic in more recent years. While we don't have direct referencing of other dimensions like you have in F360 and SW, the new on-the-fly variable creation method which has been in place since Dec. 2020 is a step in the right direction for sure!
    https://forum.onshape.com/discussion/15006/improvements-to-onshape-december-10th-2020/p1
  • ge0rge
    ge0rge Member Posts: 11 PRO
    @lougallo Do you know if this is under development? This is something that we really are missing for our Enterprise, and it would be awesome to know if it's moving in the right direction. Thanks!
  • daniel_reis
    daniel_reis Member Posts: 4 ✭
    I had the same problem. To solve I've created a new variable, but the value must be a number if it was set to Length you can't add formula in your sketch.
    Unfortunately there isn't a faster and direct way to do it.
  • gabe_g
    gabe_g Member Posts: 3 ✭
    Maybe it's the same effect, but its at least 2 extra steps. They don't need to be a variable. This is as common feature in every other mainstream CAD program, and the fact that it has been missing from OnShape for so long, despite having been asked for since it's inception is disappointing. It doesn't feel like the team is listening to people, or making an effort to make a very common, powerful and highly used and sought after feature available here. There are forum posts over 6 YEARS old asking for this feature, and it still doesn't exist. If i just want to make a relational dimension, i.e. a dimension should alwayss be half some other dimension, or whatever other constant, it shouldn't require creating variables.
    Yeah they have a bunch of features like nobody asked for yet the ones that are so basic like this one are still missing.
    Suggestion For Develoment Team: You could create this feature by creating a variable internally(hidden from the user) just the same way one can reference the face of a part by clicking it. Like the user would click Line B and then click Line B and then assign length = to Line A  / 2 (for half length for example) then store both values in a variable.
  • f_t375
    f_t375 Member Posts: 3 ✭
    Has this been resolved yet? I can't get my head around how you sketch effectively without equations linking dimensions
    S1mon Member Posts: 4,629 PRO
    It's resolved…enough. You can create and edit/modify variables from within the sketcher. So while you can't literally set d1=d2*2 (where d2 was another dimension in the same sketch) like you might have in other CAD tools, you can set one dimension to be #d2 and the other to be #d2*2 and then edit the value for #d2 while in the sketch. The only real limitation is in dimensions that are based on existing geometry. That requires a little more forethought. It's still quite possible to do a lot with equals constraints and construction lines/circles.
    It might be helpful if you can give an example of exactly the problem you're trying to solve. I'm sure there's a good way.
