Creating belt between two pulleys
gluebaby
Member Posts: 3 ✭
Howdy, I'm sort of new to CAD, but I'm creating a rock tumbler for my sister. I have a pretty basic setup, and so far everything looks alright, and now I'm trying to create a belt between two pulleys.
I've attached an image there. The pulleys look very gear-like because originally I was going to use gears, but I decided to go with a 3D printed timing belt instead. I've tried using curve patterns, manually sketching, etc, but can't figure out a way to generate a belt with teeth that match up with the two pulleys. The document is here: https://cad.onshape.com/documents/1c3f0bc7f43db3702e5291e2/w/16bfc5996eedb58af46b1170/e/4cca6effcc7d9333c9678bd0
If anyone knows how to do this, some tips would be great. Thanks!
Here is a great custom feature called Belt:
https://forum.onshape.com/discussion/11475/updates-to-the-belt-custom-feature-official-v3
Measure distance:
https://cad.onshape.com/documents/77baa8153589a7fc5f289829/v/b58988514272e25b1da139fb/e/d3174bf5315e6aafcb889367
Here is one way you could do this:
https://cad.onshape.com/documents/de9a95acec26ad35a58f312e/w/7e798a8ee55283393b3b131d/e/3c614744d07a32b2ea9352b0
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
https://cad.onshape.com/documents/9cffa92db8b62219498f89af/w/06b332ccabc9d2e0aa0abf88/e/99672d1e329b38e647d90146
