User Group Meeting: Non-traditional Onshape use
bryan_lagrange
Member, User Group Leader Posts: 980 ✭✭✭✭✭
in General
I was thinking of doing a user group meeting on unique/ non-traditonal ways to use Onshape. Items such as using features in ways other than they were intended for, or using Onshape in a non traditional way. Use it to create a house plan, facility layout, or like @chadstoltzfus a game (Onshape wordle). I used Onshape to create a unique user group logo that I saved as an image and added it to my Google slides presentation. Thoughts? Participants?
6
If we just use the file system, then the PDF would become readonly and every edit/update would require going around to 20 computers on the shop floor to ensure they do not have it open. (And we all know shop users will always leave files open, even at the end of their shift).
this way They can see all drawings that are "In Production", and updates can be pushed to them seamlessly, no matter who has it open.
Combine that with @ilya_baran's RNG.
then if you want, you can hide the available answers in another document then import them. In this case I just have the array of answers on the top of featurescript.
Now take the sketch RNG and move the dot to a random location.
It will take that vector and pass it through the PRNG as the seed, and choose an answer to play with.
While at the same time hiding the answer in the variable table! You cheaters! Although if you know how to use a debugger or what not, then of course you can still cheat.. but not much you can do to get around that one.
I chose to use a vector for the rng rather than having them enter a random number, since it is more interesting to pick a random point in space than enter a number in a box. For me at least.
Also I'm taking the Featurescript corse and wanted to play around a bit.
Wordle: Onshape Edition - RNG | Wordle
Now just need to do a proper shuffle and we may be able to play some Onshape poker multiplayer during the next User Group
June 28th 5PM central
https://www.onshape.com/en/user-group-network/professional
Twitter: @BryanLAGdesign
www.virtualmold.com
Enjoy
Onshape: Cards | Blackjack
@richard_doyle no need now for Las Vegas if Las Vegas comes to you
Now they enter the parameters into a Feature, and it spits out a full model with fasteners and flat patterns. So there is no more guessing how many sheets of steel we need to charge the customer, allowing us to be more competitive with customization, speed, cost.
Whereas before we were using an overly complex spreadsheet that attempted to add up all of the surface area. by brute force calculating flat patterns in VBA...
3 hours later I had 5 or 6 concepts to show him.
We did a web meeting where I tweaked it some more.
Once he accepted, 2 hours later I had a new approval drawing
very impressive
Grayscale
Traditional
Colorful
Does anyone know how to make extrude not fill in the inner regions?
I'd prefer not to use a stencil font.
Normal text extrude in a partstudio doesn't fill in the regions, so why does the featurescript opExtrude?
https://cad.onshape.com/FsDoc/library.html#qSketchRegion-Id-boolean
Would 20-25min for presentation work for you guys?
chadstoltzfus@premiercb.com
Do you guys have some screen shots or images of the items you will be presenting at the user group meeting?
I would like to use them to promote the meeting on social media.
Thank you in advance
Here you go!
