Notes in sketch dimensions
Axel_Kollmenter
Member, pcbaevp Posts: 436 PRO
Back in 2016 there was a question if its possible to add notes in sketches. It wasnt possible then.
Are there any news to this topic?
I know with /* Text bla bla */ I can add notes directly behind the dimension. But I only can see them when I double click on the dimension to edit them.
Is there a way to show them in the complete sketch?
Best regards,
Axel Kollmenter
Axel Kollmenter
Axel Kollmenter
Still waiting for this, would be a very nice addition to onshape. Especially if you are coming from SW and used the dimension text available there you miss this feature a lot. The workaround just isn't that great.
if you use the /* blah blah blah /* comments, you can see it if you enable "Show Expressions" in the sketch
