Can I merge two documents?
jamie_fleckjamie_fleck Member Posts: 8
I'm trying two merge two documents of mine pencap and tang.  I tried exporting and importing?  I know it's not much I can just redo the drawing.  But in the future I might have more advanced drawings.
Thank You
    Other than drawing tabs you can copy and paste into another document. I don't know if there is a way to move drawing tab from doc to another.
    //rami
    Not currently possible. You can currently copy Part Studios but that is it at the moment.
    @jamie_fleck , Onshape documents are like containers, in which they contains assembly, drawing and part studio tabs. Currently in Onshape document to document referencing are not available. User can use and copy part studio of different document. This facility is not available for assembly and drawing. User have to use "copy to clipboard" option to copy the part studio and "paste tab" option to paste in different document.In future we will hope that this facility will also available for assembly and drawing studio also.
  • jamie_fleckjamie_fleck Member Posts: 8
    Thanks, everyone.
    I think I need more sleep!
