Sketch Mode
cadmandocadmando Member Posts: 68 ✭✭
Just a very broad question, as I have been testing Onshape for the last two weeks in a professional environment.
In Sketch Mode,what are the two most useful Tools. ( Not including the most used ie line, dims, circle ect. )
The two I find most useful are:
1:   Point
2:   Coincident
Looking forward to seeing yours
Graham
    Hard to say which are most useful, 'cos it depends so much on what I'm modelling
    But here are my favourites:
    Symmetric constraint (incredibly versatile, endless applications)
    Sketch patterns (after the enduring horrors of Solidworks sketch patterns, such a delight to use)
  • cadmandocadmando Member Posts: 68 ✭✭
    Andrew
    Yes I fully agree, the Patterns Tool is very powerful and versatile, it is also available in the model environment. How do rate the Right Mouse Click in all environments, I find this a very powerful tool throughout Onshape.
    Once you think you know your way around Onshape (but not yet a fluent user) many hours can be spent exploring all the hidden tools and using the Right Mouse Click.
    Graham
    I agree that RMB is powerful in Onshape (although arguably Solidworks' RMB is even more so - and suits visual thinkers better, with icons for the most common choices)
    A strange omission from the RMB menu in Onshape, in sketches particularly, is "Delete".
    A lot of sketching could be done without recourse to the keyboard, if that omission was rectified.
    My most used favourites would be coincident and equal constraints, I have even set quick buttons for these in 3d mouse.
    And features that makes me smile every time I get to use them are pattern, mirror and use/project.
    The one in the opposite side is 'Select other' that requires too many clicks to perform..
    //rami
    3dcad said:
    ..... features that makes me smile every time I get to use them are pattern, mirror and use/project.
    Amen to that, brother!
     It seems to me to go much broader than that:
    at present, I reckon the whole selection deal is Onshape's snaggle-toothed stepchild.
    edited November 2015
    @cadmando , My most used favorites would be
    1:   Use command
    2:   Coincident constraints
    3:   Equal constraints
    4:   Copy sketch.
