Sketch Mode
cadmando
Member Posts: 68 ✭✭
Just a very broad question, as I have been testing Onshape for the last two weeks in a professional environment.
In Sketch Mode,what are the two most useful Tools. ( Not including the most used ie line, dims, circle ect. )
The two I find most useful are:
1: Point
2: Coincident
Looking forward to seeing yours
Graham
1: Point
2: Coincident
Graham
But here are my favourites:
Symmetric constraint (incredibly versatile, endless applications)
Sketch patterns (after the enduring horrors of Solidworks sketch patterns, such a delight to use)
Yes I fully agree, the Patterns Tool is very powerful and versatile, it is also available in the model environment. How do rate the Right Mouse Click in all environments, I find this a very powerful tool throughout Onshape.
Once you think you know your way around Onshape (but not yet a fluent user) many hours can be spent exploring all the hidden tools and using the Right Mouse Click.
Graham
A strange omission from the RMB menu in Onshape, in sketches particularly, is "Delete".
A lot of sketching could be done without recourse to the keyboard, if that omission was rectified.
And features that makes me smile every time I get to use them are pattern, mirror and use/project.
The one in the opposite side is 'Select other' that requires too many clicks to perform..
It seems to me to go much broader than that:
at present, I reckon the whole selection deal is Onshape's snaggle-toothed stepchild.
1: Use command
2: Coincident constraints
3: Equal constraints
4: Copy sketch.
