How do you set a linear sketch pattern to 1x?
in Drawings
I'm trying to use the linear sketch pattern and it default to 1x and 3x. I'd like to change the 1x to 6x and the 3x to 1x. The change from 1x to 6x works fine, but the software seems to refuse to allow me to set the 3x to 1x. It will allow me to change it to 2x but not 1x. How do you do this?
https://forum.onshape.com/discussion/2253/linear-pattern-in-one-dimension
ps. You have posted your question to section 'drawings', 'using onshape' would be better since this is about sketching.
