How to center a sketch on a face?
peter_loronpeter_loron Member Posts: 5
I have a part I'm working on which has an extrusion with a rectangular face. I'm trying to sketch a circle on that face, so I can extrude a cylinder from it (dowel pin). I have the circle drawn on the face in a sketch, but I can't see any way to tell it to be centered relative to the face. I'm sure this is simple, but I just can't find it.
    Hi Peter - Draw two centerlines from the center of the circle to the edges of the rectangle (one horizontal, one vertical) and attach the ends of those lines to the midpoints of the rectangular edges.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    Even simpler is to draw the diagonal of the rectangle and center the circle on its midpoint.
    Or an even simpler way is to "wake up" the midpoints of both edges of the rectangle as you are placing the centerpoint of the circle. Beat that Ilya.
  • henry_feldmanhenry_feldman Member Posts: 135 EDU
    @ilya_baran the way to beat @NeilCooke for lowest effort on your part is: have @NeilCooke do it for you (giving you zero clicks or drags!)!
    @henry_feldman wins!  :)
  • peter_loronpeter_loron Member Posts: 5
    Thanks!
