Need Help making 45 degree cut
alex_lassmanalex_lassman Member Posts: 1
Can some one show me how to make a 45degree cut in an extruded 2x2 square tube. I can make the tube but im having a hard time putting a 45degree angle at one end. or point me towards a tutorial thanks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    You should be able to create a sketch on one of the side faces, draw a rectangle to represent the area to remove, then extrude/remove
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,117 PRO
    edited May 2016
    alex-
    Build geometry:
    1. add a chamfer, select an edge RMB (right mouse button), pick on chamfer
    2. do what neil says, but add 45˚ draft to the extrude/remove to get the 45˚ cut.
    Drawings:
    Why is this under drawings? If you want to add the callout to a drawing, I have no idea.
    As per Neil's advise.
    1.gif 2.2M
    Thanks @_Dave_ I meant to say triangle  :s
    I as thinking this:
