variables
CaptainBisquickCaptainBisquick OS Professional Posts: 33 ✭✭
Renaming a variable should not break every feature that uses the variable. I can't imagine what reasoning or technical issue would have lead to variables being implemented in their current manner.
The way the code should have been written, is that every variable has a unique ID which is not shown to the user. The name is simply a property of the variable, which is shown, and so a change to the name, is then reflected in every reference.
I should not have to manually fix every feature that uses a variable just because I needed to update the name.
  • brian_bradybrian_brady Member, Developers Posts: 505 EDU
    This would be nice. I would also like variables to live outside the feature tree and be available to use in any feature regardless of when the variable was added.
    Totally agree with @CaptainBisquick
    I suppose this first iteration of variables is to examine and collect information to create perfect local+global variables to fill the most of needs. Just add feedback ticket to Onshape with any concern so it will be considered when they develop next version of variables..
    //rami
    @CaptainBisquick We agree.  I have added you all to the improvement.
