Can I create a hole centermark without a hole?
chris_sturgis
Member Posts: 25 ✭✭
in Drawings
I have a piece that comes in 4 faucet configurations. 1 w/o a faucet hole, 1 w/ 4" center holes, 1 w/ 8" center holes, and 1 w/ a single hole. I am putting all of these configurations on a single drawing, at first i tried to do this with versions of the same part studio but ended up just adding 4 of the same part in a single part studio because you cant put different versions on a single drawing. That is beside the point however.
In the main body of my drawing I am using the blank panel w/ no hole. I would like to dimension to the point where the single hole would be and then use detail views to show the hole options dimensioning from that single point. Is there a way to add a point or centermark in a random space?
Side question about center marks, can we angle them to align to a bolt circle center?
NeilCooke
Moderator, Onshape Employees Posts: 5,990
Hi @chris_sturgis - one easy way to create your hole configurations is to create your part without the holes then use Transform/Copy in Place 4 times to create new parts that are identical. You can then add your hole configurations to each of these parts and use them in your drawing.
But, to answer your question, no you can't add a centermark in space but you can add two, two point centerlines. And no, PCD centerlines do not show angled centermarks though I wish they did: please raise an improvement request in the category to the right ---->
Senior Director, Technical Services, EMEA5
