Fillets operating in reverse
simon_9
Member Posts: 17 ✭✭
I am trying to fillet between two objects - in this case a tube and the plate to which it is attached and the fillet is going down into the plate rather than merging the tube and plate on the face I want...
I must be doing something wrong but I have no clue what it might be - any help out there please?
And since a picture is better than a thousand words, hopefully the screen shot shows what I have at the moment.
Simon
Simon
Potentially the tube and the plate are two separate bodies. The fillet is not a "weld" operation. You need to do a Boolean operation on them first (add the bodies together) and then fillet if that is indeed the case...
7
7 -
Hum - well yes I think you have answered the question - however I have spent the last 30 minutes trying to do a boolean on the pieces of tube at an angle and the extrusion and I cannot get a merge to happen.
But thanks, I am sure your answer is right, I just need to join the two bodies into one.
Then the parts may be separated by a tiny bit and not allowing for boolean. Try and extrude the ends of the tubes to the other part or move them a smidge closer.0
Even parts which are touching cannot be joined, if (at ANY point) there is zero thickness.
Simplest cases: Imagine two perfect cubes whose diagonals are aligned, with corners touching. Or a round rod resting on a flat part. In such cases, a boolean merge is not viable.
Two regions of a solid cannot be connected by a single edge.
Although it's a kludge, a simple way to force contact might be to use "Move Face" on the appropriate faces of your tubes, and/or main body. It's generally better to edit the original geometrical basis, though, particularly if there are any functional or manufacturing implications.0 -
Can you change the extrude of the tubes to 'Add' instead of 'New'? This way you don't need to use boolean to combine.//rami0
Thanks for all of the suggestions - the initial problem was as suggested by Pete_Yodis, that I had more than one part.
To get everything glued together I eventually rolled back a number of steps and extruded the base plate up into the circular array of tubes and then later removed the holes now blanking off the tubes - I am sure that there is a better way but this worked in the end and that's what the objective was!
Now trying to glue the last two parts together - something I will take more care with in the future, its a pain having to rework like this when I could have done it better to start with.....However having the ability to roll back easily helps enormously.
Regards to all,
Simon0
