How does one dimension an ellipse in drawings?
michael_mcewenmichael_mcewen OS Professional Posts: 77 PRO
In drawings,  I can use the "line to line" dimension tool on a section of the ellipse, but there are no points to drag dimensions on an ellipse in plan view.  I've tried every tool.  Any ideas?
Thanks,
Michael
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    No I just don't use the vertical line at all. I showed that to show you it will extend beyond the geometry, giving you the 0.90"
    See the first post, where I used the 2 horizontal lines. When you mouse over the top of the ellipse you will see a diamond, representing the top quadrant of the arc.
    Then project that line horizontally to the left / right and click when you see the X appear near a dotted line.
    I don't have video recording software installed at work, so best I can to is type it out
    I assume you mean you cannot find a point on the plan view, but you can on a section view, because they are hidden lines on the plan view.
    OS does not allow dimensioning to hidden lines. period.
    OH, for that use a construction line
    Funny, I tried that, but when I dimension the centerline, point to point, it measures from points on the end of the lines, outside the perimeter of the ellipse,
    Because the centerline tool automatically adds a tail to either end. As is the normal intent for that tool
    so making 2 horizontal lines instead will achieve what you want
    Not sure I follow.  You draw the vertical CL, then pull 2 horizontal lines using the line tool, then dimension those, line to line?
    I get it now.  That works fine.  Thanks for your help John!
    No problem :)
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,402
    edited March 2017
    @michael_mcewen @john_mcclary
    Don't forget you can also press Shift Q when in the dimension command (providing the ellipse axis is horizontal/vertical)
    That's cool.  Thank you.  I guess I should study up on those keyboard shortcuts.  Most of those are self explanatory, but is there a video / tutorial that goes over that list?
    edited March 2017
    @NeilCooke
    Nice I didn't notice that shortcut
    Here is the list by the way.
    Yessir, will do!  Thanks again.
    Hello  - just to get you a quick answer - yes you can do it! :)
    The magic answer is SHIFT-Q
    This will activate the quadrant points that you can dimension to :)
    Philip Thomas - Onshape
    Awesome!  Thank you.
