How can I create something like this in Onshape?
paul_britton
Member Posts: 38 ✭✭✭
How would I go about creating something like this in Onshape?
https://cad.onshape.com/documents/d92d80069f785d65b6606001/w/1310ce0438cdc4020d6936ae/e/d3ad5cbe97550525c27c1044
This is a mesh imported from an STL created by OpenSCAD.
Or even just a helix around a torus? Which I can then sweep a thread around?
I'd would try to use the user interface 1st. If you're a mathematician then define it with equations.
-The 1st thing is to orient and position the mesh relative to the origin. Use translate and 2 mate connectors.
-The 2nd would be to break the pattern down to one element and work on it.
-The 3rd would be to create the element. This isn't trivial. Like Ilya said, you can use the mesh to build your curves, and then use curves to build surface lofts, then thicken surfaces to a solid and lastly pattern the element around origin to complete the design.
Can Onshape build this?, absolutely. Is it easy?, depends on who's doing it.
What is it a ring? If you were good at parametrics you could define a circle as a datum, build geometry referencing the circle and end up with a ring that'll change size for the various ring sizes. If it's not a ring, then you'd end up with something that'll change it's diameter.
I think what Ilya is showing, is that Onshape can create any surface shape. Which is true. If the curve is continuous around the origin and you can figure out the equation, then you could build this with a few equations. But I see discontinuous curves and patterns. I think I'd build it with the user interface.
https://cad.onshape.com/documents/59007ff281e43510ea3797a2/w/a6cb15bca8f1b2bf6e312ccd/e/8695694c2f658a05d1fb7da2
it can create spirals along different smooth curves
I'll have a play experiment...
looks useful for modelling lightbulb filaments too!
haha, I was just going to post a link. I told you this would come in handy!
Wow! These spirals are so cool. I would love to link your custom feature and use them to 3d print something. Can you make a V3 on your document so I can link to the 3D spiral and Evolvent features? I currently can't add them to my toolbar because there is no version that contains them.
Thanks! Here is a proposal for a code change that will allow your code to create closed splines
https://cad.onshape.com/documents/590390dc51bde5111182a458/w/fe92a4d9fcab25c6b4ab15aa/e/d631772c7e759d36921f0a56
See the change before the 'try' that executes opFitSpline
Edit: this does close the spline but it isn't a perfect spiral... best I could do on short notice. If you bump the point count way up it's unnoticeable (I used 10000 but that may be overkill)
(similar to the others posted here but with a lot more control over pitch, resolution and start angles)
Ilya - we need a much better way for users to be able to find and contribute custom features.
https://cad.onshape.com/documents/f437577a13ebbc350129b4a0/w/1873523e917e24872187e57a/e/3818058990e621d97e65afc3
