Hole Callout Issues?
drew_elliottdrew_elliott Member Posts: 2
I am having issues using the "hole callout" tool on several of my drawings. I have read through the thread here about a similar issue, but there was no resolution. I have tried the following:
Restarted the browser tab.
Logged out/in of Onshape.
Remade the drawing
Remade the holes in the part (using the hole wizard, not extruding)
The hole callout tool, does work on some other drawings, but I would like for it to work on all of my drawings. I only noticed the issue after resizing a drawing. The tool fails to work on the resized drawing as well as any drawings made since I did the resizing. I don't know if this is a causal event, it just happened right before I noticed that the feature stopped working. I am still able to designate the diameter/radius of these holes, so several of the tools are recognizing the holes just not the callout tool.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    When you say resize the drawing, do you mean change the sheet size or do you mean transform/scale the model? If it is the latter then the hole is no longer a hole it is a transform, so the hole callout will not work.
  • mark_noyesmark_noyes Member, Onshape Employees, Developers Posts: 21 image
    Please report a bug on this. We will need to get more specifics to track down what's wrong.
    @drew_elliott I pulled a ticket for you.  I will reach out here soon.
