Importing and Translating CAD data
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
We are working on the workflows of importing various CAD file formats into Onshape easy. You can do this from the Documents page but you can also import data into tabs inside of an existing Onshape document. The process is the same for files you want to download.
In Onshape there is a translation engine you can access by right clicking on the tab and selecting Translate... Here is a quick step by step to upload and translate a SolidWorks file.
**NOTE: There is an option to "Flatten uploaded assemblies as part studios" which will put all the parts into one part studio to avoid creating a number of tabs for each sub-assembly and parts.
- Click the "+" button in the lower left corner inside a document and select "Upload".
- Select the SolidWorks file from your local drive.
- Click Open. This will show a new tab with the SolidWorks icon in it.
- Right click on the tab and click "Translate..."
- A new tab will appear with the name of the file imported into Onshape. (the original tab will remain for storage and re-translation or download later)
- Right click on the tab of an Onshape Part Studio or Assembly
- Click "Translate..."
- Select the type of file format to translate to (currently PARASOLID, ACIS. STEP, IGES)
- A new tab will be created for that file type
- Right click the newly created tab and select "Download"
Examples:
http://hessmer.org/gears/InvoluteSpurGearBuilder.html
Twitter: @onshapetricks & @babart1977
