Parametric design & design intent with Onshape
emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
This is a simple part that I use in the Onshape's trainings to explain parametric design & design intention. I hope you enjoy it ;-)
https://youtu.be/kz2FBAV4w6I
Un saludo,
    one of the powerfull capabilities of OS is that it allows the degeneration of the geometry, you can have a line of zero length in a sketch, you can transform a cube to a sphere only varying fillet radius and no additional edges will stay and so on
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    Yes, We also use that in the Full Round Fillet https://forum.onshape.com/discussion/6905/new-featurescript-full-round-fillet
    Actually, now that we get variable fillets I think we should edit this FeatureScript ;-)
    Un saludo,
    What can you build with only 3 features? Now we know.
    Great video, thanks for sharing.
    That's the point of that sample. I can change the part to be a tube, a bullet, a rectangular plate, a circular plate, a full sphere a hollow sphere... almost all that you want
    Un saludo,
  • HakroHakro Member Posts: 67 ✭✭✭
    Thanks for that great video.
    Going back from zero distance doesn't always come up as desired (as it was before set to 0). I suppose Onshape has hard time to determine right direction if lenght/distance grows from zero to something. There should be some sort of mind reader implented but this is propably already in works so I don't raise an IR ticket for it =)
    //rami
    sometimes I use dimensions that change their value from positive to negative crossing zero value, and  OS remembers positive direction of dimension, I haven't faced any ambiguity of this behavior. for us this can really look like mind-reading
