Coloring faces
3dexter3dexter Member Posts: 89 ✭✭✭
One thing I miss is the simple task of coloring individual faces in a model!
I hope to see this option coloring faces and features in Onshape in the very near future!
    +1 for face / feature color (and consider this to be done also in keyshot)
    //rami
    I would like this too. I would use it when I model decal and sign's. Not high on the priority list but would be handy.
  • daniel_s_wolfdaniel_s_wolf Member Posts: 7 ✭✭
    Has there been any progress on this? I work with boards which are laminated on some sides. It would be great if I could see at once whether a non-laminated face is visible.
    @daniel_s_wolf there is an improvement request for this place your vote here https://forum.onshape.com/discussion/1293/coloring-faces/p1
    @daniel_s_wolf
    As a workaround you can use "Offset surface" with some minimal offset off the face you want to color, and then color that surface:
    https://cad.onshape.com/help/Content/offset_surface.htm
    @Jake_Rosenfeld
    I would like to represent that when there is a hole, the inside of hole is different color. That would mean 6 offset surface per part and would most certainly mess with dimension checking. Please put some priority on this standard feature.
    //rami
