Stay Signed In
Can we get a stay signed in feature? It's little, but it's a bit annoying having to type my credentials and sign in every time, especially when I'm the only one who uses this device.
  • KiseleovKiseleov Member Posts: 1
    Yes this is very annoying. Upvoted
    If you save your sign in details in your browser then it will auto-populate when you open Onshape.
  • victor_lamoinevictor_lamoine Member Posts: 3 ✭✭
    Another alternative: using KeePassXC + KeePassXC browser extension (firefox, chrome), it can autofill the credentials so that you only have to click "sign in".
  • bendhowardbendhoward Member Posts: 4 PRO
    I agree this needs to be changed. I'm able to use a password manager just fine, but it's an unnecessary few clicks every time I start my day. Gmail/Gsuite - one of the more security conscious outfits - does not make me sign in every single day. This is a totally unneeded layer of security.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,055 PRO
    The browser can remember your login too. All you need to do is click the sign in button.
  • keith_7keith_7 Member Posts: 2
    My designs are not sensitive (I'm using the free version, so my designs are all public anyway).  I see no reason that I should need to sign in every time I want to use OnShape (every few days).  I'd much prefer to sit down in front of my computer and get working straight away.  As @bendhoward says, this is how google does it (and it's perfect for me).
  • michael3424michael3424 Member Posts: 758 ✭✭✭✭
    Be thankful that you only have to log in to Onshape once - my old employer required a log-in to the VPN, again to access email, again to access the corporate web app collection and yet again to access one of the applets.  All using the exact same log in credentials.
    By comparison, I don't even notice the Onshape log in.
  • vanowmvanowm Member Posts: 135 ✭✭
    You encourage users to save their credentials in the browser, so what is the point of log them out after a few minutes? Especially when this happens during working on a sketch - it's one of the most annoying "features" in Onshape.
    If it happens when you're working then it's likely your network keeps dropping out. Onshape (or rather, websockets) require a stable connection.
  • lance_ivylance_ivy Member Posts: 2
    Then make authentication set a secure http-only cookie that is read by an endpoint responsible for generating whatever bearer token the websocket connection requires. When loading the client, try the endpoint to find out if the cookie exists and works. If the endpoint fails to return the websocket token, ask the user to log in.
