offset in bidirection in Sketch
zhifei_ge717zhifei_ge717 Member Posts: 4 PRO
I want to  offset the figure in both directions by 0.01 and form, but Onshape always says "Could not offset entities"
It's very straightforward in SolidWorks. Did Onshape change this?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    Please share the url to your doc.
    Hi - you would have to make the doc public for me to copy it (that is a read-only link). Anyway, I recreated it and the issue is that you are going from a closed region (that is 2D) to a single line (that is 1D). If you made it in two sections (top and bottom) then you could join both ends afterwards. Would SW really offset the whole profile?
  • Ben_Ben_ OS Professional, Mentor, Developers Posts: 304 PRO
    No bi directional offset is not there yet. I have wanted this for quite a while. You can use the slot function (dropdown arrow beside the offset brings this up) and then go an delete the capped ends. This is a kludgey workaround but with the right amount of lines it works out to slightly less mouse clicks.
     @NeilCooke he means it offsets to both sides of the line in one click of the offset command. Much like the slot function without capped ends.
  • zhifei_ge717zhifei_ge717 Member Posts: 4 PRO
    Thanks for your comments. I think I got what's possible with Onshape. I was expecting the bi-directional offset like that in SW, which allows me to draw centerlines of a slot network and bi-directionally expand .
  • derek_wardderek_ward Member Posts: 73 EDU
    Jake, a slot will work in instances that are simply a straight line, however, if you wan multiple connected lines or a circle you are out of luck.  A bi-directional offset is needed.
  • Andrew_GunstoneAndrew_Gunstone Member Posts: 3
    @NeilCooke is there in 2026 no bi-directional offset possible in onshape? it would be a very interesting thing to be able to do - that and to be able to make sketch dimensions equal to another without creating a variable "on the fly".. when do these kind of updates get done? 2018 was a while ago…
