If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
Offsets in Onshape
lougallo
                    Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
                    When sketching in Onshape, you can utilize the additive selection (no CTRL key needed) and select the entities you would like to offset and click the offset too or hit 'o'.  Setting direction and magnitude is pretty straight forward.  If you select a planar face you can offset all the edges of that face.
Pro Tip:
If you have connected entities and want to offset all of them, click on the Offset icon (o) and the click and drag off one of the entities and you will get all the connected entities in one shot. See examples:
Open contour:
Closed contour:
Have you noticed this behavior?
Pro Tip:
Open contour:
Closed contour:
LearnOnshape facebook group
A single curve can be offset to infinity, but with multiple connected curves there can be issues.
The problem is occurring at the inside corners of the part in your screenshot. As you offset those curves beyond a certain distance, eventually one or more of those curves ends up getting reduced to a zero length by the curves next to it. You can see this if you slowly drag the arrow closer to and then away from the part.
Onshape doesn't currently like having those curve segments being changed to zero like that. I know SolidWorks had issues with that as well.
If you want it to be offset beyond that point, you will have to offset the edges in smaller groups and then trim them manually where any of the curves intersect. Something like this quick example:
Linked[in]
In other words, offset one close closed contour and enter in the dimension, then offset another contour and enter in the dimension for that one next.
