Shortcut Menu (S-Key) mouse position
owen_sparksowen_sparks Member, Developers Posts: 2,660 PRO
Hi folks.
Tiny, tiny niggle.
Just started using a 3DConnexion device (awesome BTW) and have starting using the shortcut menu again (the S-Key) to open a local context sensitive menu.  This is great but it opens with the mouse pointer just outside the top left edge of the menu.  This seems odd for something that is meant to save mouse travel!  I'd prefer it if it opened either with the pointed in the centre of the menu or directly over the top left icon.
Cheers,
Owen S.
HWM-Water Ltd
    @owen_sparks I am not sure this needs to be voted on and it seems a very small movement for the directly over the left top icon.. But making it right under the menu is not great for accidental actions being clicked.  What would 15 px shift mean really?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,055 PRO
    While your at if modify all of the context menus in drawings.. they are are 1 menu position too far away
    Green dot represents position of mouse when right clicked
    second image is when mouse position is close to bottom edge of screen and menu adjusts upwards.
    Hi folks.
    @john_mcclary good point I concur.
    @lougallo I agree it's pretty trivial but to me at least it's one of those things that that the level of irritation is out of proportion to the problem.  A bit like having the handle bars out of alignment on your bike, or the scope out on your rifle.  Half a degree off can drive you bonkers  :)
    Take for example creating a new sketch which is top left icon on my quick launch tool bar.  By adding a mouse move we've gone from 2 operations to 3 to create a sketch.  Every. Single. Time.  And for no obvious reason.  (Sorry I don't like the answer of we deliberately move the mouse pointer away from the buttons so you don't accidentally press them.)
    Moving ahead if we had a radial menu there would be no need for a click to activate the function.  If we've opened the menu then the next icon we mouse over could/should be activated...
    Cheers,
    Owen S.
    HWM-Water Ltd
    And we all know what happens when your handle bars are out of alignment...
