Selcting mulitple entities/tools for the Split command or using surfaces with Boolean features.
clayton_ertleyclayton_ertley Member Posts: 58 ✭✭
edited May 2015 in Product Feedback
With CAD in general I mostly design Rubik's puzzles among other mechanical things.
The way I do this is to use a revolve a sketch profile about the origin of the shape I am using. It requires an invariable use of 5-50 surface bodies. This can be extremely labor intensive as I am forced to do multiple split operations and that is made even harder by that face that I have to manually select the bodies to be split which get difficult as I progress( a standard 3x3x3 Rubik's 12 splits before it is completed). Currently in OnShape we can select multiple bodies to be split, but only one tool/plane/surface.
I have attached an image to display a simple version of my problem.
I am a Rhino and Solidworks user. Respectively you can use surfaces in Boolean operations and multiple surfaces AND bodies.
I feel like the development team already has a lot on their plate at the moment that makes me feel a little guilty, but I had to suggest this. Great work so far guys! As soon as I finish moving into my new place in the coming month or so I plan to pay for the pro account in order to help with your guys funding.
I wish you the best and thanks for reading my suggestion!
-Clay
    Maybe I'm missing something here but why not use one small cube and part pattern?
    //rami
  • clayton_ertleyclayton_ertley Member Posts: 58 ✭✭
    I"m not completely sure I understand you. How would a small cube be any different the the one I have. I do a radial pattern around the appropriate axis to create the 6(in this case) surface profiles, but in order to actually make the individual pieces I end up doing 6 splits.
    In every other cad program I preform on 1 split operation.
    Maybe you could elaborate on your suggestion?
    //rami
    I cannot do that because what I am making is MUCH MUCH more complicated than just blocks.
    Here is the finished product(view and comment only):
    https://cad.onshape.com/documents/6a7c64af7a8c4b8e874512c5/w/f9551adca811463680078e88/e/8d37876fc9c64539a52db547
     Boy, that would be fun to send back in time, to haunt the dreams of a pre-CNC-era toolmaker.
    I think they would have managed OK to machine up a prototype, but making female tooling, now THAT would have been a serious challenge.
    Maybe doable on a manual Deckel, with ALL the bells and whistles...
    I would never mill a twisty puzzle. 3d printing the whole puzzle or printing the master pieces then molding and casting.
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,147 PRO
    @andrew_troup ahh the good old days of toolmaking. The things the that could be made with a lathe, a pentagraph, a drill press, a chisel, a file and some elbow grease. All those skills will soon be a things of the past with 3d printing.
    @clayton_ertley great suggestion on using multiple tools, add it in as feedback. I can see MOTW coming up with that doc (place that on as a prefix for @lougallo to see when choosing model of the week contestants). Its a very long feature, how do you go navigating it?
    Just as well you weren't designing them forty years ago, then !
    Do you mean navigating the long feature list? Well it Solidworks you can create new folder to help organize but with OnS I have just been making these for so long I have a pretty good idea where everything is. Building every puzzle in the same order helps. I was thinking of going for MOTW but I cannot decide between 3 puzzles that I have, though I guess for the more unfamiliar crowd, the standard 3x3x3 will be familiar to everyone.
    Yes I meant feature list. I made a copy to do a roll back and see how each step was done. Nice job.
    Thanks. If you like this stuff just wait until you become familiar with jumbling.
    https://cad.onshape.com/documents/5283d704088a4043bf84dd0d/w/40d246ccad6e4cee8aa77bd5/e/4eab66addd4e4cdeaf8475c4
    If you want to see what the jumbling part, this guy explains it well enough:
    https://www.youtube.com/watch?v=TagZmrnHmJQ
    Nice, I thought I was missing something on my simple approach but I'm glad now we know something of the inner workings of Rubik's cube :)
    //rami
  • christopher_owenschristopher_owens Member Posts: 235 ✭✭
    Thanks for showing me how one can share their workspace! Simple as "Copy and Paste" the  browser link! Sweet!
