Version Naming Conventions
NeilCooke
Hi fellow FeatureScripters!
As you know, it can be a difficult task to find the original document that a custom feature was created in so you can add it to your toolbar. With so many copies of each document flying around, it can look something like this:
However, if you name your versions they stand out a little better - in the image above I have prefixed each version with "Official" or "Original". Any ideas for a better naming convention?
Also, it is worth renaming "Main" to "Official" for when searching for a document from the documents page. Open to suggestions if anybody has a better idea?
Thanks.
  • konstantin_shiriazdanov
    Version naming can solve the problem to the some point, but you still can't be sure that it is original. Authors name field would give the best guarantee.
  • john_mcclary
    Good idea @NeilCooke , As long as the message gets out to all the FS writers, and people who branch specify that as well.. It should help clear up who's is the original
  • owen_sparks
    Also being able to add one's own branch in a public doc would cut down on the copies in the first place...
    O.S.
    HWM-Water Ltd
  • lemon1324
    lemon1324 Member, Developers Posts: 230 EDU
    I can certainly go through and update version names on my scripts, but I think this is a more systematic issue.
    Sorting search by links/copies would help, but really a more Github-like "fork/modify/pull request" workflow (where you can also follow links from forked copy to parent to find the original) would solve this both for FeatureScripts and geometry public documents.
    Arul Suresh
  • 3dcad
    It seems like we think alike @owen_sparks =)=)
    //rami
  • owen_sparks
    I'll chose to take that as a compliment, so thank-you  :p
    Owen S.
    HWM-Water Ltd
