Deleting an imported stl deletes all of my sketches and extrudes
hedley_phillips
Member Posts: 13 ✭
Hi,
I've imported an STL and am aware I can't edit it in Onshape so I have begun to recreate it using my own sketches and extrudes. I now want to delete the original stl import, leaving just my work but as soon as I do this, everything disappears as it seems my sketches are dependants of the imported stl.
The file is: https://cad.onshape.com/documents/a98c67ba3808e2382c3127b4/w/032e756798941e8c816b5a6e/e/65218f1f3c45e80105f40360?renderMode=0&uiState=65e379f914538c0bec80087d
I've tried to work out how to resolve this and searched but no luck so far.
Thanks,
Thanks,
That's what I did. What is the work around? Do I not reference the plane?
think I need to go and read the docs again to properly get my head around things.
Had a play and I found that when I was extruding, I was adding rather creating new.
Now when I deleted the stl, I don't see all my extrudes disappear. This is great, but going forward when I want to add a new extrude to my previous extrude but not the imported stl. How do I acheive this?
So basically. Import stl. Create a sketch and extrude it using New so it doesn't become part of the stl. But my second extude I want it to be added to the firsdt but not the stl.
Thanks,
So, the problem is when you use delete part its still in your document history, and can cause things to slow down or hit the complexity limit.
There is a way to break the links in the sketch, but still leave the points as they are. You then need to/can dimension/constrain the sketch as normal.
sketch dialong box>magnifying glass+pencil button>external references option>delete all. You need to do this for all sketches that reference the original stl. Then just go back in your history, and delete your import.
(Sorry, I am aware that this is an old post, but there is (now?) a better way of doing this, and it'd be good to have for future users searching, or possibly even op.)
