Importing .SVG Into a Part Studio
Luke_ChaseLuke_Chase Member Posts: 8 EDU
Can you import .SVG files into a plane in a part studio? I need to make something match an image/logo so I converted it to a .SVG, but I can't figure out how to put it into a part studio so I can do an extrude on it.
    kevin_o_toole_1kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565
    Also, if you want to import the SVG as sketch lines (rather than an image), you can convert to DXF and insert that.
    famadorianfamadorian Member Posts: 390 ✭✭✭
    Will SVG be supported? It's not like we don't have the math for it.
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    You can try converting it to dxf/dwg and then importing it
    place_highplace_high Member Posts: 3
    The online converters all suck, they always mess up part of the graph. Plus DXF are really not popular to export to for typical 2d software, and by default cannot be previewed on Mac/Windows. Can you add direct SVG support?
    maruelmaruel Member Posts: 3
    I used Inkscape successfully to do the conversion. It is a free open source software.
    1. In Inkscape, Open the SVG
    2. "Save As" with format "Desktop Cutting Plotter (AutoCAD DXF R14) (*.dxf)", then chose "mm" as Base unit and "UTF-8" as Character Encoding.
    3. In OnShape, create a Sketch
    4. "Insert a DXF or DWG file"
    5. Click "Import..." and select your file.
    You should be good to go from there!
    corey_mcguirecorey_mcguire Member Posts: 5 ✭✭
    No one doubts that a powerful intermediate program is a useful workflow.  We are all saying it is an unnecessary workflow. SVG should be supported natively.
    I love Inkscape, but inserting it in this workflow is unnecessary. SVG is a 23yo format.
    robert_scott_jr_robert_scott_jr_ Member Posts: 328 ✭✭✭
    Inkscape also has different file formats available via Export. - Scotty
