Frame trim
kevin_mason558
Member Posts: 64 PRO
I'm trying to trim three beams togetheri want two to meet the first and then to mitre to each other
I tried the ordered groups but the two diagonals won't splice together.
NeilCooke
Moderator, Onshape Employees Posts: 5,927
Try mitering the first two, first, then trim to the other. If that doesn't work you may just have to revert back to normal modelling features.Senior Director, Technical Services, EMEA0 -
jnewth_onshape
Member, Onshape Employees Posts: 89
As @NeilCooke said: Make the angled section with the frame tool, using the miter joint condition. Make the horizontal segment with another frame operation. Then use the trim to face to trim the mitered segments against the horizontal segment. Like so:
https://cad.onshape.com/documents/3678801b6365128570cec5da/w/0c9f8f6dc5d580acd104352e/e/9874f008ca748c105dc4f56d
found that difficult in past
but wanted them to trim between themselves as well - as shown above
I trimmed each part to a plane now.
