Rip a pipe for flat pattern
larry_nelson
Member Posts: 8 ✭✭
How do you rip a pipe so it will give you the flat pattern?
Thanks,
Larry N
Thanks,
Larry N
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
If the pipe is already created, you could first add the split to the pipe, then convert the outside face to sheet metal to get the flat pattern.5
See example above
What you do is draw your tube with a split circle
extrude a surface using the split circle
then use the sheet-metal tool to thicken that surface
Twitter: @BryanLAGdesign
when I tried split with my pipe (made using frame tool) it splits straight through into two parts
is there a way of only splitting once?
I have a pipe that is mitred then notch so there's a different shape on the two halves when it's flattened
Note that I could even do a sweep instead of an extrude to split both frame members in one go in this case
