how to turn off the lasso and use the rectangle?
tom_laheytom_lahey Member Posts: 18 ✭✭
sometimes a get the rectangle, then it will switch to lasso, how to control it while deleting
  • tom_laheytom_lahey Member Posts: 18 ✭✭
    I will try tonight, Thanks...right now it seems like all I can get is that mouse trace. it seems very elusive to get the rectangle every time. Maybe I need to slow down and let the server update me
  • martin_kopplowmartin_kopplow Member Posts: 1,279 PRO
    edited August 2024
    AFAIK there is no lasso select in OS. The selection rectangle works in a touch or surround mode depending on you drawing it from left to right or right to left, though.
    here is the lasso  and the rectangle from the snip command ,  I have not yet figured out how to turn off the lasso, it seems to have a mind of its own
  • S1monS1mon Member Posts: 4,040 PRO
    @tom_lahey
    That's not a lasso. It doesn't select things. That's a trace of where your mouse has been. It will trim bits of sketches which it crosses.
    interesting, but useless to me,, how to I get it to reliably give me the rectangle?
    In the Sketcher, if you hit the Trim tool and want to get back to selection, hit Escape (or you can click on the Trim tool a second time).
    Perhaps there's something in your set up where you're accidentally hitting the M key which is the shortcut for Trim.
    I doubt it, I am pretty mouse centric, I only use the escape key...still a newbie
