Improvements to Onshape - September 18, 2015
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
Update day is here and we are excited to show you a number of improvements in this release. Now that all of Onshape nation has access to Drawings, we will be including it as part of our core What's New announcements. Let's just get into the details!
Highlights include:
Remember: The updates listed here are now live for all users when creating new documents and over the next few days these features will also be available in documents created before the date of this update.
UPDATE:
We pushed a slight update this morning to squeeze this gem in.. ;-)
NEW Sketch slot - Now you can add slots to existing lines, arcs and splines.
https://youtu.be/ZzWzCg5M8Dk
Enjoy...
Highlights include:
- NEW Mate indicators - From any part, use the Show mates option to give visual feedback on mates applied, suppression state and whether they are solving or have errors. Hide/show mates can also be performed directly from the mate indicators.
https://youtu.be/yEvFANO0Fsc - NEW Copy parts with mates in Assemblies - When copying multiple parts, any mates between the parts will also be copied.
https://youtu.be/D7p97_da-6s - NEW Print preview - Using the print command (hamburger menu in the upper left) will now display an on-screen border, orientation and size options for easy setup.
https://youtu.be/pAIc1YucENI - NEW Export from anywhere - Now individual and selections of parts from a part studio can be exported to our standard list of formats. (This used to apply for STL only before this release and now all formats found in the export of tabs are available.)
- NEW Note alignment options in Drawings - Horizontal and vertical alignment options have been added to notes.
- NEW Drawing dimension palette symbols - A symbol pulldown has been added to Drawing's dimension palette for easy insertion of common symbols.
https://youtu.be/Ab-Pwe75_bk - NEW Mate connectors can now be used as coordinate systems for Mass properties moments of inertia calculations.
- Multi-select is now supported in the Documents page. You can take actions by using any of the gear menus in the selection set. (CTRL/CMD or SHIFT selections are supported)
- Drawings line weights now scale with zoom to support zoomed in operations (for zoomed-in, fine detailing)
- Drawing performance improvements for dragging of views and notes has been improved. (More performance improvements coming!)
UPDATE:
https://youtu.be/ZzWzCg5M8DkEnjoy...
NOTE to other users who had kept themselves up to date with the updates, and might not think to backtrack up the thread: Check out the videos posted in the OP: an explanatory video has been secretly appended, showing the slot tool.
I also like the idea of "Copy mates with parts"
Linked[in]
I'm guessing you used "Extrude with draft" for the V-grooves: how did you model the ball-ended grooves?
Single line fonts would work for this.
I first tried with draft but in the end I find it easier to chamfer the bottom of groove with same R as blade (1/2 of groove width). Ball head replication is just fillet in same way.
Spline goes with one instance in extrude:
But if you create shape using line, choosing whole sketch doesn't work - all faces must be choosed one by one.
Thanks for the info on your methods: I had forgotten that two half round fillets combine into a single full round one.
@abe_feldman :
I see the problem - there's a small region in the 90 degree bend that's being lost by the region selection and is creating zero thickness geometry because of it. If you hide the background part, you'll see it show up white when the extrude dialog is open. The reason it's getting lost is a problem for us to solve, but you can get around it by trimming the slot overlaps so it's one continuous region.
Thanks Onshape team!
