Release Management, Finding Released Items
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
I am using release management on a project at the moment and wondering if anyone has tips on finding released parts within a document. I just want to be able to select the document and surface all the latest releases without having to navigate to the versions. I know I can use the search but you have to know specific part name or number which I don't always have.
Hi brucebartlett,
When you say "finding released parts within a document" are you talking about the version + tab where the released part/assembly/etc is defined or where they are consumed?
CAD Engineering Manager
Like in this image when you click the black triangle but it searches through all versions, not just the one you have open and maybe it would also be helpful to have a way to order into product structure, however that may need to be outside of the document to combine items from across documents and released versions.
I just found that when you insert a part from a document with releases and click the black triangle it shows a list of all the latest release parts and assemblies and also places the rev level in brackets to the side. I really like this but would like to see a similar way to navigate parts/assemblies/drawings outside of the assembly insert dialogue.
Can you tell me which additional "columns" would be important for you? I assume you want some sort of search/filter based on certain metadata.
Any news on this topic since 2021?
See List View.
List View was a great step, but still needs a lot of functionality to be more useful.
Current main limitations:
-Having to navigate to the corresponding folder of the Assembly
…Ideally you could search or filter your Documents environment, and see the results in Structure View
….-Having to navigate deep into folders feels very counter intuitive in a system like Onshape
-Only available for Released Items
….This renders it useless for early development, when designs are not in Revised State (Only Versions)
-No Ability to access a Structure/List View from within the Document environment
….We need a Panel similar to the Tab Manager to see list/structure views
