Switch statement
john_mcclaryjohn_mcclary Member, Developers Posts: 3,954 PRO
Is there an equivalent way of doing switch statements in FS?
instead of a bunch of if-else statements
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,235
    There are indeed cases when a switch statement makes things simpler, but in this case, you could get a similar effect by doing:
    const table = {<br>&nbsp;...<br>&nbsp; &nbsp;3/4 : { KeySeat : .644, KeyWay : .837},<br>&nbsp;13/16 : { KeySeat : .708, KeyWay : .900},<br>&nbsp;...<br>};<br>var entry = table[ShaftDia];<br>if (entry == undefined)<br>&nbsp; &nbsp;throw "No match for shaft diameter: " ~ ShaftDia;<br>var KeySeat = entry.KeySeat;<br>var KeyWay&nbsp;= entry.KeyWay;<br>
    @john_mcclary @konstantin_shiriazdanov
    @ilya_baran informs me that there is a switch-expression in FS that we may document for public use in the future.  It is slightly different from a switch-statement in that it does not switch on an expression and then execute a block of code (a statement), but rather switches on an expression and then return another specified expression.  This can be made to act like a traditional switch statement using lambdas if desired.
    Here is an example:
    https://cad.onshape.com/documents/f6780441494046f4439a8219/w/71e7c5c95c521d8716fa75fa/e/631535138fdaba3ef7928ea2
    @Jake_Rosenfeld so this switch is a function, I beleve Ilya wrote it half an hour ago)
    edited August 2018
    @Jake_Rosenfeld well I suppose that is similar to a switch statement, but it doesn't allow flow through multiple cases, and it still requires many lines of code.
    y = 3;<br>switch(x)<br>{<br>case 0: y++;<br>case 1: y++;<br>case 2: y++; break;<br>case 3: y = 10; break;<br>default: y = 0;<br>}<br><br>X = 0 -> Y = 6;
    X = 1 -> Y = 5;
    X = 2 -> Y = 4;
    X = 3 -> Y = 10;
    X = 4 -> Y = 0;
    Not that I end up using that method very often, but it is a traditional syntax for switch which I have taken advantage of before.
    What brought this on was I had a long list of if-else statements to fill in all the keyway sizes given a shaft diameter.
    it ended up being 500 lines of code that is ugly to read.
    if they were switch statements it would only be around 100 or so lines of code and resemble a readable table.
    Vrs:
    case 7/8: KeySeat = .771; KeyWay = .900; break;
    case 15/16: KeySeat = .796; KeyWay = 1.051; break;
    case 1: KeySeat = .859; KeyWay = 1.114; break;
    Thanks @ilya_baran That's what I'm looking for for this use case
    Went from 465 lines of code down to 189 with that
    I'll know better next time :)
    @Jake_Rosenfeld
    Can you specify a default with that switch statement?
    think that is what the if(entry == undefined) is doing
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 117 PRO
    Switch no longer seems to work unfortunitally, look forward to seeing it in the future tho
    @Chris_D_Mentes_001
    What do you mean? Onshape uses it many times in their own code and we can create code just like it:
    screenshot of onshape/std/helix.fs lines 630 to 661
    Ah okay thanks for this I've been using it wrong.
