Document Search – advanced search fields and filters needed…
florian
Member, OS Professional Posts: 110 ✭✭✭
Hi community and onshape team,
I currently find the document search very limited. You can only search for document names and partial names. We have for example a document called shape_type. This document is branched for every new customer that wants it in his dimensions => new branch shape_size_serialnumber1, shape_size_serialnumber2. We will use this approach until configurations are available.
In an ideal advanced document search world I would be able to find:
- Document names and parts of it (with wildcards "*" currently not possible)
- Workspace/Branch names
- All the properties inside the workspaces (Name, Type, Part number, Revision, state)
- Custom future properties? A completely different topic
- modified by
- modified date
- owner
Suggestive search is today's standard each written letter should help you find what you're looking for. And when in document list, you should be able to just start writing rather than first moving mouse to search box and clicking focus there.
But even more, I would like to have 'HOT' documents list - which I manually maintain. I usually work with 3-10 active documents at time which I need to access all the time - after project finished I would remove this tag.
Recent list would be almost good enough for this but I'm really annoyed if I click some public model link in forum and then that document stays in my recent list like forever. Remove from recent list would be nice function also.
since this post a few things improved. We have tags now (wich I don't use yet). I just tried searching for a file. I know I have a part named: "USB-Stick" somewhere, but I don't know where. @lougallo (First name in my mind to mention) how is the roadmap on such features as described above?
A cloud PDM without simple parameter search is just as good as managing everything in an excel file: Not really useful.
––Flo
This is probably what Onshape wants, but it will also make sure that a fair share of users will turn their backs to Onshape. The Free plan is then only useable for true Open Source (and for test junk), and perhaps not even for true open source, because being able to at least make something more or less finished in a first version before showing it to the world will also be impossible.
But I love document tags and new 'move to existing doc' -feature is very handy too. It's super easy to clean up too loaded docs, just select as many tabs as you need and move whole bunch to new or existing doc. Onshape maintains all the links and connects between parts and assemblies.
While waiting for better search, try those
About public search - I don't have opinions at the moment. For me to be interested in any of current public docs, I would need brilliant search and users / models needs to be divided to at least three categories:
1. free plan user models
2. hobbyist models that are actually meant to be shared with others
3. company libraries (for standard models)
I don't ever wan't to search my documents and public at same time, for me they are two very different categories.
A-BBBif you search for stuff likeA_BBBorA BBBorA-B*…Remember the days when google had option for advanced search and there you could set specific requirements for your search, later on that has disappeared and algorithms take care of things.
I don't have MASSIVE amount of docs since I only design for one company (my own) and I would rather choose only one smart search field that would show results in smart order like 'this is the first option because last time you searched with this keyword you clicked this doc' etc
I'm not sure if this works for power users, what do you guys think?
For me it's very important to search branch names over all private documents.
