Switch statement
john_mcclary
Member, Developers Posts: 4,001 PRO
Is there an equivalent way of doing switch statements in FS?
instead of a bunch of if-else statements
2
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
I would happily use "switch" too if it was there.
6 -
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,248
There are indeed cases when a switch statement makes things simpler, but in this case, you could get a similar effect by doing:const table = {<br> ...<br> 3/4 : { KeySeat : .644, KeyWay : .837},<br> 13/16 : { KeySeat : .708, KeyWay : .900},<br> ...<br>};<br>var entry = table[ShaftDia];<br>if (entry == undefined)<br> throw "No match for shaft diameter: " ~ ShaftDia;<br>var KeySeat = entry.KeySeat;<br>var KeyWay = entry.KeyWay;<br>
Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1 -
Jake_Rosenfeld
@mbartlett21
The switch expression does not support a default, but you can check if none of the cases were hit by checking if the switch returned `undefined`, and then doing whatever default behavior you want (similar to what Ilya does above in his map example).Jake Rosenfeld - Modeling Team5
@ilya_baran informs me that there is a switch-expression in FS that we may document for public use in the future. It is slightly different from a switch-statement in that it does not switch on an expression and then execute a block of code (a statement), but rather switches on an expression and then return another specified expression. This can be made to act like a traditional switch statement using lambdas if desired.
Here is an example:
https://cad.onshape.com/documents/f6780441494046f4439a8219/w/71e7c5c95c521d8716fa75fa/e/631535138fdaba3ef7928ea2
y = 3;<br>switch(x)<br>{<br>case 0: y++;<br>case 1: y++;<br>case 2: y++; break;<br>case 3: y = 10; break;<br>default: y = 0;<br>}<br><br>X = 0 -> Y = 6;X = 1 -> Y = 5;
X = 2 -> Y = 4;
X = 3 -> Y = 10;
X = 4 -> Y = 0;
Not that I end up using that method very often, but it is a traditional syntax for switch which I have taken advantage of before.
What brought this on was I had a long list of if-else statements to fill in all the keyway sizes given a shaft diameter.
it ended up being 500 lines of code that is ugly to read.
if they were switch statements it would only be around 100 or so lines of code and resemble a readable table.
Vrs:
case 7/8: KeySeat = .771; KeyWay = .900; break;
case 15/16: KeySeat = .796; KeyWay = 1.051; break;
case 1: KeySeat = .859; KeyWay = 1.114; break;
const table = {<br> ...<br> 3/4 : { KeySeat : .644, KeyWay : .837},<br> 13/16 : { KeySeat : .708, KeyWay : .900},<br> ...<br>};<br>var entry = table[ShaftDia];<br>if (entry == undefined)<br> throw "No match for shaft diameter: " ~ ShaftDia;<br>var KeySeat = entry.KeySeat;<br>var KeyWay = entry.KeyWay;<br>I'll know better next time
Can you specify a default with that switch statement?
Switch no longer seems to work unfortunitally, look forward to seeing it in the future tho
@Chris_D_Mentes_001
What do you mean? Onshape uses it many times in their own code and we can create code just like it:
Ah okay thanks for this I've been using it wrong.
