Trim function doesn't seem to work.
paul_muller316paul_muller316 Member Posts: 9 EDU
I have drawn a square and a circle with the circle centered at the midpoint of one side of the square.  I would like to trim away the parts of the circle overlapping with the square, but nothing happens when I choose the trim function and click on the parts of the circle.  To see the trim function appear in the ribbon at the top, I click on "Sketch" and then click on the trim scissor icon.
  • paul_muller316paul_muller316 Member Posts: 9 EDU
    Neil,  Did I click on the wrong response?  -Paul
    I originally created a new sketch with just those two shapes in it to try to solve my problem.
    Thank you John.  That was the problem!
  • zbigniew_rodowskizbigniew_rodowski Member Posts: 2
    thanks, had the same problem
