Can I add notes to a sketch within a part studio
Scott_McKenzie
Member Posts: 1 PRO
I know we can add comments, but is there way to add notes to a sketch itself, similar to when doing 2D drawings.
Example:
Say I add some drawing lines for a component I want to use, a simple outline of the part to show size and location. It would be nice to be able to point to it with a note that contains the parts details. something like a drawing number, part number or details such as clearance requirements or reasons for the sketch position etc
or am i just going about it wrong.
Scott
Example:
Scott
7
Not possible as you describe. As @Tony_C_ says, you can add comments but those do not show on sketch. A work around would use the Text tool on sketch. It would be better to make a drawing, import the sketch and mark it up there. Or you could use a screen capture tool and save that on a tab if you like.
I see it as analogous to commenting a line of code ... despite the best efforts to code things to be intuitive, sometimes things just need a comment.
A useful extension of this would be to be able to annotate "TODO" action items, and then have them aggregated as a list.
https://forum.onshape.com/discussion/8526/add-notes-alongside-dimensions
Personally, I would be very happy to get something that's similar to Solidworks' capability to add text to the dimension itself which always shows when the sketch is being edited.
I'd still really like something more like what Simon is saying though, a way to color code, and add text to dimensions would be really helpful sometimes.
+1 This would be useful. Fusion 360 users also wanted this for ages and Autodesk never implemented it. After 8 years on Fusion I have finally made the switch to OnShape and I'm glad I did, because a lot of stuff that was clunky and annoying in Fusion just works in OnShape! I'm also finding a lot of "common sense" features that were never implemented in Fusion despite prevailing popular demand are in fact available in OnShape, which is a pleasant surprise, and I was a little disappointed notes/comments was not one of them. Anyone who also writes code knows how useful comments are. Heck, I use comments even on my Sheets spreadsheets all the time!
@manuel_fernandez
Often on here there are many posts proclaiming how they can't belive that this one essential feature which is on x-cad isn't on onshape. It's nice to hear something in the other direction!
I'd also like some kind of note+arrow feature, this would be really useful for making landscaping designs, and especially for presentating designs to clients in presentations or planning documentation. In landscaping you might also want to label the plants as you go, especially for more complex gardens with lots of different plants.
I came here looking for some annotation for parts drawing @EvanReese said that it is not obvious that a sketch is annotated unless that annotations bar is open.
However when the annotations bar is open an icon appears next to the sketch. but it disappears as soon as the annotations bar is closed
Why not just leave that icon visible whenever an annotation is present?
