Onshape not opening documents
david_mayhewdavid_mayhew Member Posts: 2
I've just signed up this evening and don't seem to be able to open either public documents or a new document that I have tried to create.  I keep getting the following message:
onshape not connected. Your document is saved. You can refresh the browser to continue working on this document or return to document page.
Nothing seems to work.  This is using Safari on my Macbook.
I am able to open public documents on my iPad
    Try holding "Shift" key down while invoking a "Refresh" or "Reload" of the browser tab
    I would suggest to have firefox or chrome for using Onshape.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    Safari 6 you will need to enable webgl. That sounds more like a websocket issue. Same connection on the browser and the iPad?
  • bill_seremetisbill_seremetis Member Posts: 1
    I am having the same issue and I am using a HP laptop and Google Chrome
    I have tried to "Refresh browser" but the same thing comes up
    Any ideas??
  • magret_doseymagret_dosey Member Posts: 4
    I have the same issue with Safari, but when I switched to Firefox, the problem is gone. Suggest you have a try too
  • david_mayhewdavid_mayhew Member Posts: 2
    All sorted now.  I just waited until we got a new iMac and it has been fine since.  Our older Macbook must just have been struggling.
