Can't figure out how to make a tapered symmetrical open donut
St_Sh_
Member Posts: 5 EDU
I'm trying to find a way to make something like the attached image. The closest I could get is the other attached image (basically a circle, revolved symetrically, with chamfered ends (I couldn't chamfer more than 0.9mm before it wouldn't work — why is that?). The profile should smoothly taper from the thickest, about 2mm at its center, to the thinnest, about 1.2mm at the tips. Thank you!
loft with path and a couple profiles
yep, something like this:
https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/57b37852a360893067917380
Thank you! this is exactly what I was hoping for. I will dig through this to learn how you did it.
