Why does the sketch stay in the original position when I move a part using "Transform"?
robert_mouradianrobert_mouradian Member Posts: 5
I drew a simple sketch and then extruded to create a part. I then selected the part and used "transform" and the XYZ option to move/relocate it relative to a previously created part in the same studio. If I right click and "show all" I can see the original sketch still located in the original position like a ghost. I know I don't really need to re-locate parts in the part studio, but sometimes it helps me if I keep separate parts aligned in general position they will occupy in the assembly. I also know I can hide the "ghosts" to declutter the screen, but I figure I must be doing something wrong. What am I missing?
I have no training in how to use On-Shape or any other CAD tools but trying to pick it up to use in woodworking projects.
Thanks for any suggestions.
Rob M
  • joshtargojoshtargo Member Posts: 326 EDU
    1. moving a part does not move the sketch that created it.
    2. part studios have a timeline. if you move a part, nothing that happened earlier will be aware of the Transform
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 943 PRO
    You should generally not be transforming parts in a part studio. That rarely comes up. Model the parts where they will be in the assembly. Then when you create the assembly, the parts will be automatically placed in their correct location.
    It sounds from your description that you are modeling multiple parts all on top of each other, then trying to move them out of the way of each other.
    Do the training, its super worth it.
    Another benefit of modeling parts in their correct assembly location is that you can work In Context much more effectively.
  • robert_mouradianrobert_mouradian Member Posts: 5
    Thanks to those who responded. I appreciate the guidance. It still seems a bit odd to me that a sketch and a extruded part formed from that sketch are not permanently "connected" but it sounds like that is the normal behavior, so better to avoid moving parts in the part studio.
    Thanks again,
    Rob M
    @robert_mouradian the sketch and the part are permanently connected, but only one way, in a part studio, time only flows down the feature tree. think of it like cause and effect. everything above your Transform has already happened and can't be affected by events that happen after them.
