shortcut key for top, front and right planes
don_howe
Member Posts: 136 ✭✭✭
I have printed off the list of short cut keys provided by Onshape but I don't see a short cut for selecting the top, front or right planes. Am I missing something here? If I zoom in on a part and I need to create an sketch on the right plane I have to scroll to the top of the feature tree to select it. This is not very productive in multi-part documents. Tell me Onshape has a shortcut key for this.
Use the shortcut 'p' button, show/hide planes, and click select the one you want. Press 'p' again to hide.
This may be worth putting forward an improvement request - I have run into the same problem with 'wide' scenarios. I like the 'p' shortcut as it just involves a quick scroll and click, but getting rid of that step would be good - so plus 1 for instant one-click plane selection (of the three major planes).
https://forum.onshape.com/categories/improvement-requests
In future we hope user defined shortcut key facility will be provided by Onshape
@don_howe One solution would be to have 3dconnexion 3d mouse which has the buttons you need and more (front, top, right and turn).
It does cost some money but I have found 3d mouse with it's buttons almost replacing keyboard while modeling.
