Randomly shifting lines by .0001 and scuffing entire projects seemingly at random
jayce_fryjayce_fry Member Posts: 5
everything is constrained, everything is exact, 72cm x 72cm x72cm x72cm. but then at random while working somewhere else, it just moves things… and refuses to log it as a change so you cant revert it or undo do it in the change log. just SOL days of work? gone.
HA went to go get a screen shot, and while ALT tabbed, not even in the soft ware it changed something else and now nothing works at all lmfao
And what did i catch it do before this you may ask? well it resized one of my sides to 71.999999999999 and made none of my lines fit anymore. then did this
Oh i guess i wont be making this for the 3rd day in a row of this exact thing happening.
thanks on shape very cool
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Please share the doc URL. Top tip: keep sketches to 10 lines or so, not 500. Just asking for trouble.
  • MDesignMDesign Member Posts: 1,265 PRO
    Not sure what the context of all that repeated work is but generally you'd only want to do maybe 1/8 of that and then mirror/pattern the rest of it.
  • S1monS1mon Member Posts: 3,775 PRO
    It seems like you could pattern one rectangle and maybe do a couple of mirrors. Manually drawing all of that in a single sketch is not the way to go.
    edited January 20
    @jayce_fry blue dots in your sketch means it's not constrained.
    You can use 3 consecutive sketches to control complex constraint schemes. If you saw the constraint matrix for your input, it's a mile long.
    @NeilCooke that's a old pro/e proverb. Keep your sketches to 10 entities. I haven't heard that one for a long time.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,473 PRO
    edited January 20
    Your sketch is too complicated and you are likely hitting the limit of number of constraints within a sketch.
    • Your sketch seems symmetric so I would only draw a 1/4 (or even 1/8), which would help a lot…
    • Also the "staircase part" should be a separate sketch, or maybe even does as features rather than a sketch.
    We might be able to point you in the right direction if we knew what you were trying to design…
  • jayce_fryjayce_fry Member Posts: 5
    @billy2 yeah it went into a "refresh" crashed and deleted a ton of stuff and did that.
    @eric_pesty its a game board for game from Dune, so pretty much a chess board,
    i just never though of doing it in quarters as I've had this issue with onshape on every project ever and didn't want to put too much thought into something i knew was going to get destroyed by an error haha
    @jayce_fry I read in another post that you spent 5 hours in this one sketch? The data is only commited to the database when you exit the sketch, so yes if it crashes within that single 5 hour sketch editing session then yes all the data will be gone. That's another reason to keep sketches simple.
    @jayce_fry power of mirror w/ constraints
