Randomly shifting lines by .0001 and scuffing entire projects seemingly at random
jayce_fry
Member Posts: 5 ✭
everything is constrained, everything is exact, 72cm x 72cm x72cm x72cm. but then at random while working somewhere else, it just moves things… and refuses to log it as a change so you cant revert it or undo do it in the change log. just SOL days of work? gone.
HA went to go get a screen shot, and while ALT tabbed, not even in the soft ware it changed something else and now nothing works at all lmfao
And what did i catch it do before this you may ask? well it resized one of my sides to 71.999999999999 and made none of my lines fit anymore. then did this
Oh i guess i wont be making this for the 3rd day in a row of this exact thing happening.
thanks on shape very cool
Please share the doc URL. Top tip: keep sketches to 10 lines or so, not 500. Just asking for trouble.
Not sure what the context of all that repeated work is but generally you'd only want to do maybe 1/8 of that and then mirror/pattern the rest of it.
It seems like you could pattern one rectangle and maybe do a couple of mirrors. Manually drawing all of that in a single sketch is not the way to go.
@jayce_fry blue dots in your sketch means it's not constrained.
You can use 3 consecutive sketches to control complex constraint schemes. If you saw the constraint matrix for your input, it's a mile long.
@NeilCooke that's a old pro/e proverb. Keep your sketches to 10 entities. I haven't heard that one for a long time.
Your sketch is too complicated and you are likely hitting the limit of number of constraints within a sketch.
We might be able to point you in the right direction if we knew what you were trying to design…
@billy2 yeah it went into a "refresh" crashed and deleted a ton of stuff and did that.
@eric_pesty its a game board for game from Dune, so pretty much a chess board,
i just never though of doing it in quarters as I've had this issue with onshape on every project ever and didn't want to put too much thought into something i knew was going to get destroyed by an error haha
@jayce_fry I read in another post that you spent 5 hours in this one sketch? The data is only commited to the database when you exit the sketch, so yes if it crashes within that single 5 hour sketch editing session then yes all the data will be gone. That's another reason to keep sketches simple.
@jayce_fry power of mirror w/ constraints
