Boolean in Sketch mode
Jiroscopes
Member Posts: 4 ✭
Hello, I am needing some kind of boolean for sketch mode and I cannot figure it out. I have a part that I want half of it trimmed off but I cannot do it so I just used a bunch of little boxes so I could select the sections I want for extrude which works but seems wrong. Is there a better way?
https://cad.onshape.com/documents/59e69049eadd796a33a6bf0f/w/e104dcff6e61c6678d347ac8/e/904eeec4e5d2889ee94c392b?renderMode=0&uiState=679402d11c8472626462709c
Not sure what exactly your trying to do. need more specifics. maybe the website learn.onshape.com would help.
I think this is what you're looking for. Your sketch wants to be trimmed better and built with constraints.
What are all the squares for? Done correctly you won't need fillers.
Lot's of free training in Learning Center.
https://learn.onshape.com/
https://cad.onshape.com/documents/c17c66a6cf811c1ce2c3bad1/w/01bb196c5dbf9192ffb635ef/e/a4fc995195f08cabdbe199b5
