Improvements to Onshape - January 31st, 2025
NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
edited February 21 in New in Onshape
The second update of 2025 introduces integrated cloud-native CAM, sheet metal forms, and a raft of improvements to drawings.
CAM STUDIO (BETA)
CAM Studio is now available to all Onshape Professional and Enterprise commercial subscribers.
https://onshape.wistia.com/medias/u0alsll49b
PART STUDIOS
SHEET METAL FORM
You can now create form features, such as louvers, bridge lances, slot embosses, extrudes, and punches on existing sheet metal models. In addition, you can create your own library of custom forms, and this release ships with a set of forms to get you started in the Onshape sheet metal forms library.
https://onshape.wistia.com/medias/ayrjzorcjc?embedType=web_component&seo=true&videoWidth=640
SKETCH CHAMFER
A new Chamfer tool in sketch enables the quick addition of chamfers between entities.
https://onshape.wistia.com/medias/s3k9hx6htc?embedType=web_component&seo=true&videoWidth=960
DRAWINGS
PARAMETRIC SKETCHING
Lines, circles, and points added to a Drawing sheet can now be constrained and dimensioned relative to drawing view geometry.
https://onshape.wistia.com/medias/leaja4dgyn?embedType=web_component&seo=true&videoWidth=960
STACKED CALLOUTS
Callouts can now be stacked to detail groups of related parts or parts within close proximity of each other.
https://onshape.wistia.com/medias/etsoicbka5?embedType=web_component&seo=true&videoWidth=960
DETAIL VIEW BORDER
The border of a Detail view may now be shown clipped to the view geometry for added clarity.
CUSTOM KEYBOARD SHORTCUTS
All commands in Drawings can now be assigned custom keyboard shortcuts.
EXCLUDE OFF SHEET CONTENT
Off sheet content can now be excluded when exporting drawings in DWG, DXF, or DWT file formats.
https://onshape.wistia.com/medias/aaldxsps3x?embedType=web_component&seo=true&videoWidth=960
RELEASE MANAGEMENT
ADD ITEMS TO OBSOLETION
Multiple objects from the same document or from other documents can now be grouped and obsoleted together, reducing the number of steps required and creating an association between obsoleted items for audit purposes.
LEARNING CENTER
INTRODUCTION TO CAM STUDIO
A brand new course, Introduction to CAM Studio, is now available on the Learning Center to coincide with the release of CAM Studio. Learn how to build a machining job in CAM Studio and preview real-time tool paths, back plotting, and machine-accurate simulation.
INTRODUCTION TO PARAMETRIC FEATURE-BASED CAD
The Introduction to Parametric Feature-Based CAD course has been completely reworked and updated with new content and examples to help new users get up to speed with the concepts of 3D CAD.
LOCALIZATION
In our continued efforts to expand our localized offerings, full French audio has been added to the Self-Guided Onshape Bootcamp.
«134
  • Nick_HolzemNick_Holzem Member Posts: 146 PRO
    edited January 31
    A lot of long standing requests here, keep them coming! Drawing sketching, detail view boarder clipping, and remove permanently delete global permission for workspace deletion (change log). Building an obsoletion change is also going to save some time on occasion. Nice work!!
  • andrew_kelly561andrew_kelly561 Member Posts: 4 PRO
    Brilliant so much to get excited about in one update. Nice work team.
  • Cedric_EveleighCedric_Eveleigh Member, OS Professional, csevp Posts: 70 PRO
    Please keep putting resources into CAM. Thanks!
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 872 ✭✭✭✭✭
    Parametric sketching in drawings +
    Formed features in sheet metal ++
    CAM studio released +++
    Excellent update. Thank you Onshape Team!
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 82 PRO
    Wow wow, this must be the best release ever. Very good , thank you !
    Finally after years of waiting, the simple fillet in sketches is here 🙂
    I will start using parametric sketching immediately, maybe even update drawing templates.
  • jonathanb_sydneyjonathanb_sydney Member Posts: 21 PRO
    edited February 1
    Wow, sheet metal forming, sketching improvements, excluded drawing content, stacked callouts, this stuff will get use from day one. Very happy to see these features finally roll out of production🎇
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 453 PRO
    Amazing update! I can't imagine how much work the Onshape team put into this!
  • maxwell_smartmaxwell_smart Member Posts: 19
    Can't wait for the student access to CAM!
  • GWS50GWS50 Member Posts: 455 PRO
    what a fantastic update, full of extremely useful functionality. Can't wait to dig into CAM studio. Drawing tools are a great improvement
  • FarraFarra Member Posts: 9 PRO
    i cant see the form option in mine ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,873
    Please see the footnote in the OP 😁 should be there early next week.
  • aeromorrisonaeromorrison Member Posts: 62 PRO
    Amazing release! I'm looking forward to digging into these updates.
  • fstfst Member Posts: 78 ✭✭
    Great update!
    "CAM Studio opens up a lot of possibilities and makes Onshape much more competitive against some other CAD tools, although the pricing is quite a bit different."
    Technically yes, practically no, it is not competitive at these prices.
  • STEGSTEG Member, User Group Leader Posts: 124 PRO
  • Chris_D_Mentes_001Chris_D_Mentes_001 Member, csevp Posts: 116 PRO
    This is HUUUUGGGEEEE !! Well Done Holy Molly!
    Love all the drawings space improvements, love the keyboiard shortcuts and I've had the CAM for a while now as a BETA tester but nice to see it's hitting the main stream.
    I must say I've noticed that the CAM is aimed at metal work for now which I assume is why HOMAG machines have not yet been added to the list. For over a year now I've wondered if I'd ever get a chance to properly test the CAM out so hopefully that is still on the horizon.
  • Alex_PittAlex_Pitt Member Posts: 69 PRO
    Wonderful update! So good to have a sketcher in drawings!
  • alexey_kornienkovalexey_kornienkov Member Posts: 2 PRO
    Wow, sheet metal forms at last! Congratulations. That's a really big step for those of us using sheet metal a lot.
  • michael3424michael3424 Member Posts: 735 ✭✭✭✭
    The CAM system seems to be a lot more mature than I would have guessed given where it is in the development cycle.
    Is/will there be a utility available to create machine definitions and post processor generation or will these only be available directly from Onshape?
    Will TCPC be supported for 5-axis work?
  • Nath_McCNath_McC Member Posts: 133 PRO
    Some great updates!
    I had a quick play around with CAM, and maybe it's just me, but I feel like it's nowhere near ready. The inner machining menus feel clunky and difficult to navigate, especially when working with designs that are more complex than the example part provided. It’s quite challenging to get the desired results efficiently.
    I'll check out the "Intro to CAM" section and hopefully, that will help make things easier to navigate.
  • Josiah_HarthcockJosiah_Harthcock Member Posts: 57 PRO
    Love this release!
  • hagushagus Member Posts: 4
    Where can we get the list of supported machines for CAM? And can the Carvera CNC be added if it’s not there already. I’m DYING having to do this in Fusion360.
    I haven't got access to any of the CAM stuff or the docs … can someone clarify if custom gcode is supported so I can add my Carvera if they don't have support for it already?
  • Yam_SYam_S Member Posts: 48 ✭✭
    Not getting simple 2.5 axis Cam for "standard" subscription is a real disappointment.
    other than that, a great update.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 982 PRO
    Its only available in the professional and above plan.
