How can I extend a Ball Screw
I have import a ball screw that measures 300mm but I need it to be 400mm how can I extend the threads?
Thank in advance
  • robert_scott_jr_robert_scott_jr_ Member Posts: 606 ✭✭✭
    Hey Felix. Welcome to Onshape. In this document I took a segment of the screw out of the 'middle', duplicated it, moved the appropriate segments and booleaned all the segments back together. Planes and surfaces could also be used as split entities. - Scotty
  • eric_pestyeric_pesty Member Posts: 2,275 PRO
    "Move face"/translate "should" work, so I would try this first…
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 985 PRO
    In this particular instance of commodity CNC parts, the vendors usually have the all the lengths they offer as cad models. That's another option.
  • félix_antoine_couturefélix_antoine_couture Member Posts: 5
    Thanks to everyone for the advice
  • john_lopez363john_lopez363 Member Posts: 126 ✭✭✭
    edited February 11
    @félix_antoine_couture. It's quite simple to model a ball screw… if this is going to be a recurring issue for you, you should try modeling it natively!
    https://cad.onshape.com/documents/bd82b4fd7cadb5f185aab397/w/10f66ca82ef2c5c41a22ccf7/e/3969aaaf23f6f70f8394f2b3
