Move letter from text
Hello
I'm not new to CAD, but to OnShape.
If I create a text with several letters in the sketch mode, how can I move just one letter? If I use the transform option the whole text moves along and not just one letter. Can I somehow de-link these letters?
Any help appreciated.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,472 PRO
    Short answer: no (and I'm not aware of any parametric CAD that would do that)!
    There are likely a number of workflows that can achieve what you need but can you tell us what you are trying to do and/or share a document?
  • MDesignMDesign Member Posts: 1,265 PRO
    When you extrude the text. The individual letters will be separate parts. You can the. Use the transform tool on each letter.
  • jacob_steinerjacob_steiner Member Posts: 4 EDU
    Thanks.
    I try to do something similar to "create an exploded view for drawings" in Autodesk. I want to move the letters together to get one piece.
    I've found this question, which is basically the same I've asked:
    Then extrude separately and move the bodies so they overlap, "transform by mate connector" might be a good option to control things precisely.
