Export an IGES file of a 3D part drawing
nazaire_verrue
Member Posts: 4 ✭
Dear ,
I want a 3D drawing ( 3D part drawings ), in a IGES file and it does not work to me . What can cause this?0
Surfaces will not be shown in a Drawing
Yes, it is a solid bodie. A part.
I would export to an IGES file. It does not work to me.
It seems you are trying to export a part model in IGES format.
(Drawings in Onshape are a different thing from models, and so that word confused me)
If you are following the procedure at
https://cad.onshape.com/help/Content/exporting-files.htm
and no valid IGES file is generated, you should share the model with Onshape support and use "Feedback" to report the issue
The IGS file opens in the program Mastercam. I can import an IGES file. The edges are not imported in the Mastercam. What must I do to EDGES would be imported also? The surfaces to be imported into the Mastercam
Not sure why iges is not working.
(The 80 character file format arose from the number of holes used in punched card programming, and IIRC it was developed by the USAF for military use, having purchased the underlying translator from Boeing for $1):
I'm always more surprised when IGES does work than when it does not.
