Create tetrahedron?
Hello
What is the right way to create a tetrahedron in onShape?
I can make an equilateral triangle and then loft it to a specific point,
but in this case I need to manually calculate the correct height of the tetrahedron.
Is there any better way to make it?
Thanks much!
Thanks much!
clayton_ertley Member Posts: 58 ✭✭
This is how I do it. I use a hexahedron/cube for reference geometry.
https://cad.onshape.com/documents/c139928c548f4436bea91dfc/w/957c1ccb7ac94f13a7d49f98/e/716f71e783b94399945fb48c
EDIT: In this way you have the origin of the tetrahedron at the same place as the origin of the planes. You can rotate it however you want.
5 -
viru Member, Developers Posts: 619 ✭✭✭✭
@alexander_potochkin, @andrew_troup @brucebartlett @clayton_ertley , No need to calculate height manually. Now Onshape provided variable option with the help of that you can create very easily as shown in below video. You have to define only edge length (Variable a) other will update automatically.
You can refer below document link for tetrahedron creation.
https://cad.onshape.com/documents/b4d69938124444a5964aa70c/w/0134d50029bf4711a734b71a/e/c19d7dad093249fd9668b605
8
I tried to link angle with a variable but that does not seem possible yet.
https://cad.onshape.com/documents/5f90e0c61c164cb5bf4141cf/w/b4350e5bf94349dc871ed0bb/e/de54a518e7af4756bf334182
Will it properly recalculate if I change the size of the base triangle?
One slight snag with your construction: the side you have set equal to the side which is 200mm long measures only 173.205, which is to be expected because an equal relation is true in the plane of the sketch, not in 3D.
So the equality is NOT with the length of the other line, but with the projection of that line onto the sketch plane
This is discussed elsewhere on this forum, including here:
https://forum.onshape.com/discussion/1576/equal-constraint-use-with-care-between-sketches
I don't know offhand what the angle of a tetrahedron is, but if you check it I think you might find it's rather more than the 65.9 suggested by your model
I guess the obvious remedy would be to link the line length in sketch 2 to the line length in sketch 1 using a variable
(I haven't had a chance to explore them thoroughly but I presume this would be straightforward, although your post suggests this does not yet work for angles)
I just can not work out how to get the angle into the draft on the extrude.
The linked post is very wordy, because we were trying to find our way to the root of the issue.
Here's the executive summary:
# Constraints which operate between sketches ALWAYS project the remote sketch entity to the destination plane before solving the constraint.
The only exception is the pierce constraint (where a projection would be inherently meaningless: it would not result in the specified result)
Currently AFAIK the only other Onshape situation which does not ever rely on this sort of projection is constraint to a remote plane (rather than to a sketch entity).
NOTE: This # behaviour is common to all similar MCAD modellers: it is not a bug.
In other words, this behaviour is (justifiably, almost unavoidably) BY DESIGN.
You can see in my model that I used a cube with an edge length of 60mm. This method will always yield a tetrahedron with an edge length of 84.852. Meaning that the ratio of the
Cube edge length to tetrahedron edge length is (1 : 1.3642). You can use this ratio to predetermine the edge length of the tetrahedron.
Nice! Kudos to you
Now I definitely know what onShape tools I should have a look to.
What a wonderful community here!
Have a great day.
Alex.
I made a cube and sliced a tetrahedron out of it.
https://cad.onshape.com/documents/d21a14adc0ef4fa09095b29d/w/79bbbe32437a42df9980f7ea/e/30a56b8e579348c084f6f188
Thanks again
Draw a square and extrude with side length as a variable.
Create a plane that intersects three of the points of the cube so that they make an equilateral triangle.
Sketch a circle on the new plane that also intersects all three points. (doesn't have to be a circle but I found it easiest)
Extrude (by variable) and Subtract the circle from the cube, lopping off the corner.
Repeat the Plane/Sketch/Extrude for the remaining three corners.
It might take a little more time to draw but it is much more satisfying as it's a perfect tetrahedron.
- sketch triangle
- sketch one of the other edges (using an equal constraint)
- loft to the point
Here's a quick video. I like it because there's no math, no variables, and only 3 features.Of course, to do it in one feature you could use the Polyhedron feature too
Independent Onshape Consultant | Industrial Designer
https://cad.onshape.com/documents/93f2dfdea0555d930849c033/w/738de8482a5a2e6f9d440e97/e/a1b6010751a1e7e89ecc3d2a
